Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Oppo BDP-103 and 105 2 channel stereo audio quality - Does the DAC difference matter?
  1. #1
    Junior Member SholaBaby's Avatar
    Join Date
    Jul 2013
    Location
    Manama, Bahrain
    Posts
    9
    Hello everyone,
    I have just got myself Oppo BDP-103 player after lotsa research and review reading to decide against its big brother the 105. Now I am thinking, have I made the right choice? Should I have gone for the 105 in spite that it costs twice more than the 103? As I have gathered from all that I read about them, the difference between them actually lies in their audio output through their DAC chips. 103 uses Cirrus Logic CS4382 DAC chip while 105 uses ESS Sabre32 Reference ES9018 DAC chip. So the question now is have I made a right choice by going for 103 giving the price of 105 being twice as much? Is their any significant difference in their 2 channel stereo analog audio rendition? All I just want is the sound to get as close as possible to vinyl's analogue level —warm and soft to the ears, but so far 103 is doing okay as I use it with my old JVC AX-R 551BK Integrated Stereo Amplifier —cool and tight sound ...
    Please folks, help with your opinions... Thank you.
  2. #2
    Quote Originally Posted by SholaBaby View Post
    Hello everyone,
    I have just got myself Oppo BDP-103 player after lotsa research and review reading to decide against its big brother the 105. Now I am thinking, have I made the right choice? Should I have gone for the 105 in spite that it costs twice more than the 103? As I have gathered from all that I read about them, the difference between them actually lies in their audio output through their DAC chips. 103 uses Cirrus Logic CS4382 DAC chip while 105 uses ESS Sabre32 Reference ES9018 DAC chip. So the question now is have I made a right choice by going for 103 giving the price of 105 being twice as much? Is their any significant difference in their 2 channel stereo analog audio rendition? All I just want is the sound to get as close as possible to vinyl's analogue level ówarm and soft to the ears, but so far 103 is doing okay as I use it with my old JVC AX-R 551BK Integrated Stereo Amplifier ócool and tight sound ...
    Yes, there are differences and the 105 is a better-sounding player via the analog outputs but, despite the encomiums, the difference is not huge. Depending on the resolution of your system, the quality of the source materials and your listening habits, it may make a significant difference to you or it may not. But, since you already have the 103 (and 30days to return it), why not decide for yourself if it offers the sound you want? You can always spend more.
    _____________________________
    Kal Rubinson
    "Music in the Round"
    Senior Contributing Editor, Stereophile
    http://forum.stereophile.com/category/music-round/
  3. #3
    Join Date
    Jul 2013
    Location
    Manama, Bahrain
    Posts
    9
    Quote Originally Posted by Kal Rubinson View Post
    Thank you very much... The problem is I do not know how small or huge the difference is as I have never had them operating side by side. As I have mentioned, I am only using it with my old JVC AX-R 551BK Integrated Stereo Amplifier and Pioneer CS-607 speakers which I do not think are of the kinda resolution you are talking about but as I have said, to my ears the sound is cool and tight though not as close to the analogue sound from my vinyl LP album collections. So what do you reckon sir?
  4. #4
    My suggestion was for you to evaluate, based on your system and your experience, whether the 103 satisfies your needs for sound and for improvement over what you had before. I suspect that it should and doubt whether your system justifies the increased expenditure for the 105.
    I am intentionally ignoring your vinyl references because I cannot relate to them.
    Kal Rubinson
  5. #5
    Join Date
    Jul 2013
    Location
    Manama, Bahrain
    Posts
    9
    Thank you... Yes, that was what I was wondering myself if it will justify it and I do not watch movies a lot in any case so in essence I will be using to play music more than watching movies. So I guess that really answer my query then. Thank you sir. Really appreciate your help and advice.
    Be blessed.
  6. #6
    Addicted to Best!
    Join Date
    Dec 2010
    Posts
    10,258
    Be blessed.
    Personally, I have found the Oppo responds well to a little damping or isolation. You may have already thought about this. Isolation underneath and a damping plate on top make a nice improvement over the 'solidity' of the tone/signal. I also found using a Sablon Audio power cable made a nice improvement. They also have a 30-day money back, and the Owner is top notch on service in my experience. (no affiliation though I do know the owner).
  7. #7
    Join Date
    Jul 2013
    Location
    Manama, Bahrain
    Posts
    9
    Quote Originally Posted by lloydelee21 View Post
    Oh no ... I am not really aware of this. An AC power cable? I thought the OEM cables are sufficient enough for any electronic appliances such as this, i.e. Music systems, Computer systems, TVs, etc. Well this a new info to me. Wow! Thank you for the info. Keep learning new stuffs every day, huh...
    Be blessed...
  8. #8
    Banned
    Join Date
    Apr 2010
    Location
    Seattle, WA
    Posts
    16,044
    If they allow 30-day returns on both, get the 105, do your own comparison and return the one that you don't like. And post the results here . The observations on which sounds better is subjective so it may not apply to you. Best to do your own testing if you can.
  9. #9
    Member Sponsor [Technical Expert] DonH50's Avatar
    Join Date
    Jun 2010
    Location
    Monument, CO
    Posts
    3,517
    Note if you are using the HDMI outputs they are the same... For music the start-up lag (or "dead time" at the start of a CD) is less using the analog outputs.
    Don Herman
    "After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
    Don's Technical Articles on WBF
  10. #10
    Quote Originally Posted by DonH50 View Post
    I find the difference insignificant but that might be due to having the HDMI connected anyway.
    Kal Rubinson
Similar Threads
  1. Oppo BDP-103 & BDP-105 Universal Blu-ray Players :: Reviews & Opinions.
    By NorthStar in forum Oppo Blu-ray Players DAC and headphone amplifier Forum
    Last Post: 08-15-2016, 05:00 PM
  2. Variable remote volume control on BDP-105
    By Ki Choi in forum Oppo Blu-ray Players DAC and headphone amplifier Forum
    Last Post: 05-21-2013, 02:31 PM
  3. Anyone here have experience with the Oppo-105 modded by Modwright
    By taters in forum Digital Audio Forum: DAC, Transports, Digital Processing
    Last Post: 04-01-2013, 10:11 PM
  4. What's Best for Redbook: Oppo BDP 95 or Mytek 192 DSD DAC
    By jackiejr in forum Digital Audio Forum: DAC, Transports, Digital Processing
    Last Post: 01-20-2013, 06:36 AM
  5. Oppo BDP 93 State of The Art for $500 if you have a DAC
    By Mobiusman in forum Digital Audio Forum: DAC, Transports, Digital Processing
    Last Post: 04-21-2012, 08:02 AM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
