Upsampled SACD's
Gregadd
1,781
1,850
Metro DC
Fraud!
jimtavegia
17
I do understand what you are saying and that, I am sure, your analogue gear is first rate, and that only the increased noise floor (albeit very low) is the only real issue for you. Thanks for the information.
It is no different for me and my lesser 2496 recordings for the local University. The HVAC noise is so bad (-50 to -55db) that it is so frunstrating, but even the improvements of 2496 do shine through, just much of the low level detail is buried. We are working with central engineering to program the HVAC systems to be turned off during the concert/recording times. Hopefully getting near -75 or -80db, hopefully. It is live so the patrons do come into play. It is still clear how much better 2496 is then redbook. Even with the noise I will still do 2496 all the time.
Thanks again to all who responded.
MylesBAstor
81
1,725
New York City
amirm
Banned
Apr 2, 2010
15,813
37
Seattle, WA
Biggest problem with SACD and to some extent DVD-A, was admonition from ripping them to a PC at a time, when that was all the rage. It is the mass market which helps support these formats and without that feature, they would not come along.
At the time, I actually went and bough all the "Audio DVDs" (not to be confused with DVD-A) because I could rip those. High-end audio guys should have stayed with that format, rather than switching to DVD-A and SACD.
RUR
3
SoCal
Biggest problem with SACD and to some extent DVD-A, was admonition from ripping them to a PC.....
An admonition is not necessarily a deterrent, Amir. At least, not for we 2ch guys, and not if one is willing to "settle" for PCM. Never tried multi-channel.
Yes, I own every SACD/DVD-A I rip.
amirm
Banned
Apr 2, 2010
15,813
37
Seattle, WA
Well, it was at the time they were introduced. I recall DVD-A being the only one hacked at at the time through Creative player. SACD remained "secure" until its timing window had run out.
RUR
3
SoCal
What do you use to rip an SACD
Sorry, Steve, I've overstated my ability re: SACD i.e. I'm only ripping the CD layer. I've read posts on how ripping the SACD tracks is done, but they all involve bits of expensive gear. I can dig that up, if you wish.
HDAD's may also be ripped, but one loses the last bit, and they simply don't sound the same, IME.
Bruce B
Apr 25, 2010
7,006
512
1,740
Snohomish, WA
www.pugetsoundstudios.com
Ouch! HDTracks and Pugent Sound would be named as well as they were fully aware?
When we first started doing this, we did not check the SACD's to see if they were hi-rez. It all came to a head when we ripped over a hundred BIS labeled discs and found out they were 24/44.1 upsampled discs. I think HDtracks is still fighting that one. Now we check each and every track that goes out of here since we've found discs that contain both hi-rez and upsampled data... Go figure..
To get the DSD layer off of a SACD, you will need 3 things.
Transport: Playback Designs MPS-5 via ST-optical out
Converter: EMM Lab ADC8 IV which accepts the ST-optical in and streams out DSD via SDIF-3
Capture: Pyramix MassCore DSD workstation via SDIF-3 in.
Another way we do it is to take the Playback Designs ST-optical stream directly into a Sonoma system.
Regards,
RUR
3
SoCal
Transport: we use the Playback Designs MPS-5 via ST-optical out
Converter: we use the EMM Lab ADC8 IV which accepts the ST-optical in and streams out DSD via SDIF-3
Capture: we use the Pyramix MassCore DSD workstation via SDIF-3 in.
Regards,
Thanks, Bruce. May well have been a similar post of yours I've read on another forum.
'Tis a pity, too, since my PWT won't play SACD/DVD-A/HDAD and I'm forced to rip as I can to wav or flac. Digital out from my Modwright/Denon uni-player simply can't compete with the PWT. Level-matched and double-blind.
jimtavegia
17
Pushing aside the fact that Sony did not support the pressing of their own format, I still think the "dedicted player" is what killed SACD and DVD-A for the masses. Other than they find MP3s just swell. I wonder what would the landscape be like if Sony from the get-go created multi-layer discs, even if they ditched the MC from SACD. Maybe the manufacturing process was just too cumbersome for them. If every DVD player was like an OPPO, the world would be a much better place. lol Play them all and stop worrying.
What I like is that my DVD+R with 2496 pcm files will play on any DVD player know to man. No dedicated player...no problems for anyone I hand a disc to. HooRay!
propa
2
check the box
Interesting thread. It is very much to HDTracks credit that they check what they sell.
The key when buying SACDs is only to buy discs that state the recording resolution on the box. If they don't state it, ask the label first. If the SACD labels don't get their act together, this will just cause uncertainty and doubt, and the format will suffer.
I don't buy any BIS discs because they don't state their recording resolution ... and it is apparently just 44.1 kHz (24 bit).
Kal Rubinson
2,361
702
1,700
NYC
www.stereophile.com
And does that handle mch as well as stereo tracks?
4,700
Bruce,
A naive question - the MPS-5 output is SDIF-3 format? What is the purpose of the EMM Lab ADC8 IV?
