Qualia Indigo
wizard
856
2
16
wizard-highend.blogspot.com
The ToneAudio review is here
Indigo looks like one of the best phono stages out there.
mep
17
$60k and no loading adjustments?
mep
17
With 69dB of gain, you shouldn't need a SUT except for mc cartridges that really have super low ouput. The reviewer used a Denon 103R which has .23mv output and it worked just dandy.
rockitman
7,097
412
1,210
Northern NY
Without loading options, I cannot see how the sound would be optimal. Maybe I am missing something here.
mep
17
Christian-From what I read of the review, this phono section was designed for mc cartridges which have a low impedance.
MylesBAstor
81
1,725
New York City
But that shouldn't obviate having to load? Even something like the Air Tights that are around 1 ohm need to be loaded.
mep
17
Myles-This $60K phono section loads the cartridge alright, it's just a fixed load that has to be *right* for the cartridge you are using. Personally, I think a fixed load for a phono preamp is a non-starter.
audioarcher
1,396
51
970
Seattle area
Since this phono stage works better with low impedance carts I wonder if it is a current amplifier instead of a voltage amplifier like most phono stages. I know of only a couple other phono stages that are current amplifiers. The ESE Labs Nibiru and Aqvox phono. I had the ESE Labs Nibiru for awhile and it also had no loading adjustments. The designer said they were not necessary with his design. I did not really find a need to adjust the loading with the Nibiru but since it did not have any option to do so I'm not sure if it would have helped any.
I would not spend $60k on a phono amp with only 1 MC input and no MM option personally. Especially when you are limited to low impedance designs as well. I really dislike not having options.
audioarcher
1,396
51
970
Seattle area
I looked at the Qualia website and it says it uses current mode amplification as I suspected. This would explain why you need to use a low impedance cart. From what I understand the higher the impedance of the cart the lower the output will be. This also explains why there is no need for loading adjustment. With current mode amplification supposedly there is no need for it.
rockitman
7,097
412
1,210
Northern NY
It's an interesting albeit ridiculously priced phono stage. The Ypsilon is half the price and could be the reference standard using their optional SUT' for whatever load you require. Personally, I like loading on the active stage itself.
audioarcher
1,396
51
970
Seattle area
Agree. The price is insane. The billet enclosures are nice but probably account for $3k of the cost to build it. I wonder what the signal to noise ratio is on this unit. It does not say in the specs. My Nibiru was not that good in that department. It was ok for it's price range but I'm sure there are better.
catastrofe
106
Saint Louis
This is the same principle as the BMC MCCI. The BMC is a fantastic stage. . .the Qualia is almost 20 times the price. Hmmm. . .
Peter Breuninger
Jul 20, 2010
1,231
4
Here is a look at some Qualia gear:
mep
17
My concern about the Ypsilon besides it's price is that it is built in the world's economic stronghold...Greece. ;)
Part of the financial problem in Greece is too many businesses don't enough pay taxes. Too much income goes under reported.
