That little brush scares the heck out of me!
Johnny Vinyl
May 16, 2010
8,570
51
38
Calgary, AB
My Ortofon 2M Black comes with a brush that's about 1/4" in diameter and appears to be really stiff, and it scares me to death using it. Does anyone have an alternative brush for a DRY application (recommended by Ortofon)?
Here's a pic of the brush:
I'm very careful, but I'm also afraid of damaging the stylus with this thing.
mep
17
Use Oznow and Stylast.
Johnny Vinyl
May 16, 2010
8,570
51
38
Calgary, AB
I use the Onzow as well....never tried Stylast....I was thinking of buying a very fine artists brush or make-up brush and then using the Onzow.
vinylphilemag
Apr 30, 2010
810
1
328
56
Kelowna, BC
www.vinylphilemag.com
Don't worry, I've been using that sort of brush for YEARS with no problems. Just make sure that you brush only from back to front!
I use Stylast too.
Johnny Vinyl
May 16, 2010
8,570
51
38
Calgary, AB
I use Stylast too.
OK...I'll get used to it I guess. Back to front? OOPS! :p
mep
17
Oznow first, Stylus second.
Peter Breuninger
Jul 20, 2010
1,231
4
I love to scare listeners and hence use a hard brush when the volume is up. Don't worry, the little diamond will not be bothered by the bristles. Been doing it for 25 years. If you think this is scary, Garth showed me that from time to time he uses the striker on a matchbook!
cjfrbw
1,355
1,730
Pleasanton, CA
Magic Eraser. Cut off a small piece, put it on your record or mat, drop the needle on it with your arm life then lift back off. Works almost always, but a brush once in a while is usually needed as well. You can also just leverage a piece to clean directly if you are careful.
I have one of the Ortofon brushes, too, and it also scares me, it is so dang stiff. The soft bristle part of a soft tooth brush works well and has a long handle.
flez007
2,915
36
435
Mexico City
I can`t recall which of my previous carts came with a similar brush, never had an issue using it.
DaveyF
6,129
181
458
La Jolla, Calif USA
John, I wouldn't worry about that brush. It's the same type that Stylast was using for years with their stylus cleaning solution. I used it for years. Not the most effective, but IF you brush gently from back to front will certainly do no harm. BTW Peter, Garth must have gotten his matchbook idea from Linn. They came up with this years ago. At the time, the idea was pretty much discounted; although I'm not sure I would use this method today either.
The Onzow zerodust is the best I have found for stylus cleaning.
treitz3
Super Moderator
Staff member
Dec 25, 2011
5,476
1,001
1,320
I'm a user of Magic Eraser as well. No issues to report here.
Tom
Johnny Vinyl
May 16, 2010
8,570
51
38
Calgary, AB
Thanks guys. I think one of my issues is that it's awkward to hold ...wish it had a more user-friendly design to ensure a safe grip.
But, I won't worry about it and use it plus the Onzow.
Happy spinning! :D
Blam!
16
Germany
No problems with that brush here, I've been using that kind of brush for years. And also an AT 637.
mep
17
I am a firm believer in Stylast. I have been using it for many, many years and it has never caused a problem and my cartridges seem to have a very long life indeed.
vinylphilemag
Apr 30, 2010
810
1
328
56
Kelowna, BC
Same here. Magic Erase and the like scare the willies out of me because it might leave behind traces of chemicals that shouldn't touch one's records...
JackD201
1,428
1,820
Manila, Philippines
I think I've had 6 or more Ortofon carts to date from different Concord and OM MMs as well as an A90. No problems with their brushes. All of the styli are fine.
rockitman
7,097
414
1,210
Northern NY
The brush will be a necessity at one time or another whether you use Onzow/magic eraser or not. Sometimes stuff gets caked on. I have even seen an onzow chunk get stuck on my A90. It's getting old and probably should be replaced.
cjfrbw
1,355
1,730
Pleasanton, CA
"onzow chunk". Now, there's a term only an audiophile can love (or understand). But I agree, sooner or later the brush of some sort will be necessary. A lot of analog gremlins can be scotched by clean needle.
