9in vs 10.5in vs 12in arms. Which would you choose?
Believe High Fidelity
[Industry Expert]
Nov 19, 2015
1,666
321
355
Hutto TX
ibelieveinhifi.com
Fremers position is that 9in is best and certain manufacturers only make one length so you don't have a choice. However, if you did have a choice would you choose:
9in
10.5in
12in
Lets assume that there is no difference at all in the tonearm and they will all be built with the same material, specs. Only difference would just be the length.
Any supporting reasons to why you chose your particular length would be much appreciated...
-Joshua
cjfrbw
1,355
1,730
Pleasanton, CA
I think it depends on tastes and goals. If you like a filmy, evanescent and ethereal presentation, than 9 inch with a high compliance, low output cartridge and a belt or DD tt.
If you like a fuller, meatier, dynamic and more tape like presentation, a 12 inch arm with low compliance cartridge and a high quality idler arm tt. Those would tend to be the playback "poles". For inbetween, use inbetween variants. Turntable "mass effects" also matter.
Bruce B
Apr 25, 2010
7,007
515
1,740
Snohomish, WA
www.pugetsoundstudios.com
Really????????
ddk
6,261
4,043
995
Utah
9in
10.5in
12in
-Joshua
Hi Josh, before jumping on Fremer can you link where he said that so we know the context, because it sounds like the type of hype I read in respect to SAT and the designer's claims?
david
JackD201
1,429
1,820
Manila, Philippines
When I had a VPI HRX I needed a 10.5" wand for the Phantom to clear the periphery ring. I got more wands after that. I've been 10.5 inch ever since. Nothing to do with sonics, just necessity that turned to habit.
Loheswaran
437
101
273
we can be going in circles
david
I had a good chat with Max Townshend. whom I think is one of the great TT Engineers out there. In short he advocates the use of 9 inch arms for tortional stiffness. He said this outweighs the tracking error problems of a 9 inch arm versus a 12 inch arm.
Do bear in mind that the Townshend benefits from a trough - this in many ways locks a cartridge in the groove - not only this but the trough prevents a cartridge from sudden mistracks. To this end the tracking errors are minimised by the shorter arm. I say this all because conventional 12 vs 9 inch arms don't get the benefit of the trough - therefore Max's view may be 'less' correct in the conventional arm debate.
As an aside I think the Schroeder parallel tracker is the way forward - ask yourself this question guys - would you want the Schroeder with a 12 or 9 inch arm?
Remember that in essence it is application. Increasing length is not a cure all. There are a load (if you don't mind the pun) of other factors to consider. Affect to suspension, compliance are all important factors.
ddk
6,261
4,043
995
Utah
I have 9", 10", 12" models of several tonearms and can easily compare apples to apples which I've done. With these arms I can equivocally claim that the 12" sounds best, not only with better tracking ability but better, deeper and more natural bass, airier highs and quite a bit of solidity. Of course none of this will show up if your table and system isn't up to the challenge.
david
Reactions: elem79
beaur
Fleetwood Sound
Oct 12, 2011
460
166
950
60
Brooklyn
Trite, but whichever one sounds better. Not locked into any orthodoxy that would require choosing based on one parameter. I have one table where a 9" or shorter arm is the longest I can install. I have another table where a 12" is the shortest arm I can install.
Also as far as I am concerned the table/arm/cartridge work as a team. Choosing pieces in isolation may not be the wisest move.
9in
10.5in
12in
-Joshua
4,704
(...) Lets assume that there is no difference at all in the tonearm and they will all be built with the same material, specs. Only difference would just be the length. (...)
-Joshua
IMHO you are assuming something impossible - some of the fundamental specs of different length tonearms, such as inertia mass and resonances must be different. You can not keep all of them. As the specs of different length tonearms will be different you can not separate the choice of length from the cartridge selection.
Mike Lavigne
Apr 25, 2010
12,602
11,695
4,410
my experience with 4-5 years of listening to various testing sessions (with multiple lengths) of Durand tone arms in my system, as well as hearing Joel's perspective about many multiples more from his own testing, as well as my prior and subsequent experience results in my preference for 12" tone arms among tone arms I have heard.
however; my intuition tells me that execution is more significant than just length at the top of the food chain. and context is almost as important. and that the last word on the truth of this subject has yet to be written.
I would love to compare the 9" SAT to my 12" Durand Sapphire Telos in my system.
dan31
1,020
369
1,653
SF Bay
I agree, it's all in the execution. That said the 10" Spiral Groove Centroid is the best arm I have heard. Now I own it and it is very satisfying. Any well designed arm can be a great product.
jfrech
2,157
753
1,160
Austin
+1
ddk
6,261
4,043
995
Utah
Compare the same tonearm in 9", 10" & 12" versions then you'll hear the advantages of the longer tube not random ones, then it's just A vs. B which isn't what we're talking about here.
david
[Industry Expert]
Nov 19, 2015
1,666
321
355
Hutto TX
ibelieveinhifi.com
david
It was in an Analog Planet video I watched in the last 30-60 days. Will try to find it for you
[Industry Expert]
Nov 19, 2015
1,666
321
355
Hutto TX
ibelieveinhifi.com
The goal is that if you have the choice from a Bespoke vendor that offers the same arm in all lengths and you can choose which length you want. Granted they will all be different as stated in their own ways hence the question as to which one you would go with and why. If there are compromises in your choice which one would you want to go with that has the least in your opinion. This is the direction of the question
[Industry Expert]
Nov 19, 2015
1,666
321
355
Hutto TX
ibelieveinhifi.com
Lets say the table has an mounting system separate from the table negating any compatibility issues.
[Industry Expert]
Nov 19, 2015
1,666
321
355
Hutto TX
ibelieveinhifi.com
Were they tonearms of the same kind or different models of various brands that happened to all sound better with the 12in offerings used?
4,704
Then IMHO you will have to try all three to know which you prefer, or just rely on dealer/expert/audio forum opinion. :rolleyes: And with another Beespoke vendor you have to do it again from start.
If we consider that the tracking error is the most important compromise in a tonearm we should go with a parallel tracking arm.
Mike Lavigne
Apr 25, 2010
12,602
11,695
4,410
prior to my Durand experiences I did own various 9" and 10.5" inch arms, a couple of Graham, Triplaner, 3 Reed, and Schroeder. I also owned the liner tracker Rockport Sirius III arm for 8 years.
while involved with Durand testing mostly they were 10.5" and 12" with many different arm wands and various materials. the current arm wands on my 2 Durand Telos 12'' tonearms are both composite.
[Industry Expert]
Nov 19, 2015
1,666
321
355
Hutto TX
ibelieveinhifi.com
