I had the chance to listen in my system the following DACs in direct comparison:
- Aqua La Scala
- Aqua Formula
- Lampizator DER7 (special edition of Lite 7 with GG parts
- Lampizator GG single and balanced, several tubes
- ANK 5.1 silver signature
I personally prefer High Level Red Book standard (like with Jadis, Oracle or other real high End CD drives) over DSD conversion
(yes, SGM was playing in my home as well)
my impressions :
- Aqua La Scala
good starter level into the world of involving DACs, but too much missing, so finally I did not listened too long to the DAC
here the music starts playing!, using Kron 242 the GG sibling with solid state PSU rocks, a big step from Aqua La Scala
I can understand, that in some mid size set ups the difference to GG is minor.
- Aqua Formula
Wow, that was an easy task, just better than DER7. Higher resolution, better staging, clearer contrasts, like a better focussed picture of the same music., but a little less involving power...
- Lampizator GG single and balanced, 2016 level, integrated R2R , several tubes
I was using all the time RCA connections in the set up, so also the balanced GG was running on RCA. At first I have to mention, that an balanced GG runs better on RCA than a single ended GG. I discussed this with Lukasz on my last visit to Lampizator in Poland. He mentioned, that the PSU works in a better balanced mode in a full balanced GG and that this can result in a better performance even while using RCA outputs.
GG clearly outperformed the Formula in all aspects in my set up (even the GG single)
The Formula lacked the flow and the inner energy a GG can provide. the Formula was not that much involving than GG, still a very good performance, but with GG you are not stopping to listen to music, with Formula you start faster track skipping....
- ANK 5.1 silver signature with 3 shunt PSU, so NOT the standard 5.1 offered on the web side as kit
ANK in Canada is producing an Audio Note UK like level 5 DAC with the same old DAC Chip as Audio Note UK or the popular Kassandra is using.
My ANK DAC is equipped with 2x Kron 5U4G Rectis Lampi Edition (love the sound) and other good tubes.
In my personal opinion the ANK has even more inner energy and dynamics's than the GG. The GG has a slightly higher resolution at the top end, but directly compared I connected faster to the music, than even with the GG.
Finally I could not judge, which DAC I would prefer GG or ANK, both bring me close to the music!, GG can do DSD, which I am not using at all. ANK is optimized for Red Book (understands 24/96)
In the meantime I had the chance to use a
- Total DAC
as well , but not in direct comparison. From my memories, performance was on DER7 level, but with a different sonic character.
