Driving is different from the speaker having the same oomph, mid bass, bass, drive, soundstage - some speakers come alive withe right muscle and sound lifeless but pleasant when driven be SETs. Now, I have no idea what power and control you used on the Vandy, but I have seen an AR 250 struggle to drive the Vandy 7 (83 db), and was acknowledged by the owner who was then looking for a change of amps.
Wow...thanks for that! Very interesting, Morricab. I respect your views on SS, though based on your description, Gryphon's pure Class A focus with no negative feedback seems a good start.
absolute power corrupts absolutely.
I love to be corrupted.
High power amplifiers usually have much higher capacitors, special care to isolate the input/driver circuits from the output stage, avoiding coupling through the supplies, thicker copper tracks and wires, more heavy and robust mechanics - all these aspects can result in a better sounding amplifier. Designers could easily have all these features in a model with lower voltage rails with lower power, but the marketing departments do not appreciate a model costing five times more and having half the power!
Do you mean class B here or class AB? The latter was invented to deal specifically with this issue.This is why zero crossing distortion in Class AB, push/pull amps is an issue. This discontinuity as the signal passes zero volts (where the two transistors hand off one to another) causes a burst of high order harmonics, is very audible and cannot be eliminated with negative feedback. It is the elimination through use of Class A amps that is one of the big advantages of Class A.
This is what Ralph Karsten said about 2nd vs. 3rd - and I would agree its not so simple.
"Actually I am not a fan of lots of 2nd harmonic. And our amps really don't have any on account of their being fully differential- the 2nd is cancelled out at each stage in the amp. So this is a case where the topology can be used to control the distortion signature- we tend to get mostly the 3rd harmonic, and do as much as we can to keep it down, as we do with the output impedance. Is that a Kool-Aid? Dunno. It is certainly an attempt to keep known-distortion sources (pentodes, transistors, transformers) to a minimum, in order to reduce distortion. Some designers don't worry about distortion (SETs are typically 10% at full power, our amps are closer to 1%)."
We can all agree SET basically introduces loads of 2nd harmonic - whether this is audible or objectionable is up to the listener. People who like OTLs probably don't like SETs and vice versa.
Thank you. Do you believe that the human can discern certain kinds of distortion better than others (ie, human ear can pick up 1% 3rd order distortion more easily than 1% 2nd order distortion)? Sorry for the remedial questions...just trying to follow this interesting debate.
Good evening gents
Couple of questions to this debate.
1,Has anyone seen distortion measurements throughout the audible band, for coventional speaker/panels/hybrid?
Let us say at 95db.Not even talking about 100db.
How do these figures compare to any amplifier.Set or otherwise.
2...say that a dominant 2nd order harmonic is euphonic.Whould you be surprised to know that the overwhelming majority of speaker drivers produce 2nd harmonic dominantly? would not make this all speakers inherently euphonic?
3.Would not the level of these even order speaker distortions, a magnitute higher than the distortions present throught the electronic chain, dictate how euphonic the sonic result is?or not
4.A chip amplifier with 40db feedback will be virtually distortionless at steady state.Combined with a speaker producing 2% distortion at 100Hz would it have more correct timber than the same speakers driven by a set with 0,1% distortion?
5.If a set can change the timber of an oboe then why do the 99% of the speakers in the market do not produce indistinguishable blabber noise instead of music.Mind that you must first answer #1
6.An amplifier with a major 2nd harmonic distortion will cancel the speaker's 2nd harmonic thus producing third harmonic.If connected in phase it will amplify the second hamonic.If we follow your logic, then just connecting the speakers out of phase would make the set sound like PP and the opposite.Apparently it does not.
Please take these in a friendly tone.
Cheers
Stavros
Thanks for taking the time
1.0.1% at what frequency and especially what level?85db? What about 95-100db.We are talking about realistic listening levels.
Distortions sub 500Hz and above 5.000Hz are above 1% even at ~90db.
2.Most drivers produce 2nd as dominant,panels especially their ribbons and the non-push pull panel motors.In horns,depends on the horn loading as well.
3.As i mentioned,speaker distortions are >1% below 500 and above 5000 at realistic listining levels.A good set will have 0.1% within .So yes,a magnitude higher in harmonic content will have a dominant effect(but of course not completely)
4.Sub 500Hz is,IMHO the base of music,orchestral or not,and this is where the majority of speakers start to fail.And as correctly stated,their hp will be all over the midband
5.The point is that 0.1% H2 will not change the timber of any instrument.I will agree that relevant changes is what matter.
6.Even harmonic cancellation is mathematically predictable,and measured.A chain of two components,either that is pre and amp,amp and speakers,even gain stages of an amp,will cancel H2 if in phase, and produce odd harmonics(usually higher than H3).
SO, here is the question.If a set sounds euphonic because of H2(hypothesis),and as the speaker will have H2 as dominant distortion profile(fact), the SE amplifier as dominant H2(fact) ,would the amplifier sound non euphonic if connected out of phase?(H2 cancelled)
It does not.
Cheers
Stavros
Hi Stavros,
this could go on like ping-pong!
1. 0.1% is possible from ~250Hz to 1500Hz up to realistic listening levels. Not common but available.
2. My concern about my horns has always been more about sound reflections within the horn, very similar to the tuning of the induction and exhaust of racing engines
I have never seen a clean waterfall plot from horns, for example.
3. A good wideband speaker will not have distortion >1% as high as 500Hz simple 2 ways with small main units, maybe. A good 3-way with well engineered bass unit(s) go much lower than that. A quick look at the measurements of the well engineered but modestly priced (£1000) KEF R300 shows 0.7% @ 100Hz, 0.1% @ 1kHz and 0.1% at 10kHz at 90db, which is a realistic sound level IME. At almost double this price the Revel F36 has 0.4% @ 100Hz, 0.2% @ 1kHz and 0.1% @ 10kHz. Something mega like the Wilson Alexx measures 0.1% @ 100Hz. So I still don't agree with you about the speaker having a magnitude more distortion than the amp nowadays.
4. Because the speakers in 3 above achieve the performance they do I think you are exaggerating the speaker contribution at 500Hz. It is still contributing, yes, but not dominating the contribution of an SET type amplifier to the degree you suggest.
5. 0.1% will change the timbre IMO but it will change the timbre of all instruments similarly, so the instruments will still sound relatively similar but the individual timbre of each instrument will have had its timbre slightly changed.
6. In order to the 2nd harmonics to cancel they not only need to be out of phase but also of equal magnitude over the whole frequency range. This is highly unlikely/impossible from 2 different pieces of equipment so I do not believe connecting them out of phase will cause complete cancellation so the logic of your point here fails, the fact that they do not cancel proves nothing, and is even what should be expected.
I don't doubt that your amps sound lovely btw, I have heard many superb reports that they do!
cheers,
Frank
Hello Frank
time is gold,and i respect my client's time, and yours, to pursue a ping pong game at the forum,so my last ball return would be below.
1.Have you had any real world distortion measurements of speakers?You will surprised to know that a 6db increase in output does not increase distortions by 6db. You will be surprised how fast distortions pick up after 95db.
Realistic listening levels are just that.Realistic.No room for opinions unfortunately,even acoustic un-amplified music peaks over 100db easy.That level should be at listening position.So add another 12db for 4m meter distance(6db for 2m) ,half of that for true line sources.
Have you seen real world distortion measurements at that levels?
10% for bass drivers,while tweeters ....well
Speakers do have one or two levels of magnitude higher THD when we are talking about realistic sound pressure.90db peaks is not realistic.Even vocals way surpass 90db.
2.Just because you haven't seen one it does not mean it does not exist.(what horns did you measure?)Commercial horns suffer from bad horn construction(resonances) ,poor flare choices(HOMS),bad termination(diffraction) among others.These will result in bad "waterfall" measurements.A proper horn can eliminate these problems..I will use an analogy you will appreciate more,if i spend my life driving cars with leaf suspension,it does not mean that racing suspensions do not exist.
(BTW i can show you horn-driver combo distortions , of -70db H2, at SP levels that most drivers will self desctruct.However, It does not mean that your average 100K floorstander will not have it's drivers jumping out of their magnetic gap at 105db
3.See 1
4.See 1
5.I am not arguing that,which is correct!I am arguing that 0.1% is audible,and various tests prove it is not.
6.If the amp and speaker have comparable H2 levels,and their distortion increase is monotonic,there will be a cancellation.No full ,but at least -20db.
One hour ago you did not know H2 cancellation existed and now you disregard it.I have measure it.Many have.It does happen.And it does not make an SE sound like a PP ,or the opposite...Food for thought
Again in a friendly tone.
Thank you for the compliment Frank,much appreciated.
Best
Stavros
From Audio Electronics by John Linsley Hood (1999)
IMHO we must be very careful when debating distortions - what are the thresholds that separates "inaudible" from "euphonic" or "harsh"? Again IMHO we can not separate qualitative from quantitative opinions in this subject.
Years since I last saw this but it is the evidence that listeners find 0.5% added 2nd harmonic distortion to be "more musical" which leads to the idea that people may well chose a piece of kit which adds this sort of distortion because they prefer it.
Again "does it sound good because of the distortion or despite it?" question, and again I firmly believe the former.
