What's best in highly sensitive/efficient speakers.
853guy
Active Member
Aug 14, 2013
1,161
10
38
What are the cream of the crop in the highly sensitive/efficient speaker world? Speakers that can be powered with say a 10 wpc SET amp?
Both in box and horn loudspeakers (excluding the obvious Magico ultimate).
Box ones:
Living Voice OBX-RW (94dB/6 ohms)
Devore Fidelity Orangutan 0/96 (96dB/10 ohms)
Horning Eufrodite (98dB/8 ohms)
Horning Agalme (102dB/6.2 ohms)
Audio Note UK AN-E (98dB/6 ohms - though JA measured it at 92.5dB)
Horn ones:
Cessaro Chopin (97dB/6 ohms)
Cessaro Affascinate SE (100dB/8 ohms)
Gamma 1 (107dB/8 ohms)
Living Voice Vox Olympian
G.I.P. Lab 9700-A
G.I.P. Lab 7396 (Western Electric Mirrorphonic recreation)
Western Electric 15a
Western Electric 16a
I had the Living Voice OBX-RW's. I actually preferred them higher-powered tube/Class A SS amps - lower powered SETs and tube PPamps didn't really bring them to life. I also preferred them without the external Kondo wire as it made the harmonics too splashy. It was actually these speakers that moved me away from my active ATCs and down the greater sensitivity/efficiency path.
Unfortunately, I've not heard any of the others, though I'd love to and may do so this year.
Peter Breuninger
Jul 20, 2010
1,231
4
I awarded the Voxativ a Gold Show Award for sound at Newport this year. They are amazing speakers.
Reactions: ihmeyers
hvbias
578
38
940
New England area
One of the great high efficiency box speakers I've heard was the Daedalus Ulysses. I had the pleasure of having an extended audition at a customer's house and they are really natural sounding and very well priced. I would have ordered a pair if I weren't going down the custom horn route.
andromedaaudio
8,495
2,843
1,400
Amsterdam holland
I should have said business then,its all relative .
Well if youre talking extremely good for almost chumpchange then i dont need to look far , but as i dont use expensive cables nobody takes me serious :D
Job?? That's inheritance/trust fund territory!
That's my yearly salary!
dallasjustice
2,067
8
Dallas, Texas
I like Voxativ. I am not a horn fan. I have heard them in 4 different rooms, 3 different shows and they always sound wonderful.
Keith_W
1,024
95
970
Melbourne, Australia
www.whatsbestforum.com
I have heard quite a few high efficiency speakers. All of them have trade-offs which you may or may not find important, depending on your preference for sound.
- Large horn speakers (e.g. Avantgarde Duo, Trio, or Acapella): the most explosive dynamics and able to fill the room with sound. However, more often than not the horns do not integrate properly and imaging is very poor. Needs a large room and budget.
- Dual Concentric (e.g. Tannoy). I have heard quite a few of these, and nearly all of them have natural lifelike dynamics (horns can sound a little excessive), wonderful coherency, and superb imaging. The downside is the rosy coloration or a midrange thickness that makes everything sound rather 1950's. The other downside is that they should not be played too loud, otherwise you may damage the speaker.
- Full range single driver (e.g. Coral). I have not heard a single one of these speakers which I like - rolled off top and bottom, and they sound small and incapable of filling a room with sound (unless you have a small room).
- Boxed multi-driver (e.g. Zu and WLM). These tend to vary quite a lot and do not have a sonic signature which can be generalized to the whole class of speaker. I find most boxed speakers to be fairly boring in sound and it's difficult for me to get excited about these.
Reactions: Nascimento
Duke LeJeune
Jul 22, 2013
751
1,216
435
Princeton, Texas
My nomination would be Classic Audio Loudspeakers. The current generation models I've heard (T-1 and Hartsfield) simply sound like live music, smooth and relaxing to the point of being totally effortless, and with no distracting little colorations to ruin the illusion... such colorations being the downfall of many otherwise very promising high-efficiency systems. The Classic Audios are not just high efficiency, but also very tube-amp friendly (the two are not necessarily the same thing). I have no affiliation with Classic Audio Loudspeakers, aside from admiration for John Wolff's work.
http://classicaudioloudspeakers.com/cgi-bin/index.pl?fs=1&content=17&menu=15
andromedaaudio
8,495
2,843
1,400
Amsterdam holland
There are a lot of factors involved ,you cant only base the choice on eff , ive heard 99db hornsystems improve considerably while going from 18 watt to 200 watt in terms of dynamics /control , if a speaker doesnt really change in those fields while going fom +- 8 watts to 300 watt then you got something
But as there is no [ CE ]industry approval /standard ,manufacturers can claim anything
KeithR
5,174
2,864
1,898
Encino, CA
Shindo Latours would be a fun audition. Ditto on Voxatv at Newport.
I run Zu Definitions at a much lower price point, but feel they are sublime and compete with 30k speakers. 101db, although require 25 watts imo.
spiritofmusic
14,626
5,435
1,278
E. England
Let me second KeithR re Zu spkrs. Running a pair of Zu Definitions 4 on the end of 30W/ch Audion Black Shadow SETs. Totally sublime, effortless sound "all of a voice" with the FRDs and lack of crossover, dripping in tone, full bass extension and slam, and sublime treble. V. room friendly with full range of adjustments on built in active sub bass drivers.
Keith_W, consider giving Zu another chance, esp. the Def4s.
Robh3606
1,484
474
1,155
Destiny
Hello Keith
I agree and that's mostly due to the types of horns used and how they are arrayed. Typically they are set-up so the directivity of the individual horns gives you separate focus points for each bandwidth. Not a good idea and probably the primary reason for the less than stellar imaging.
You need to look at systems that use more modern horn types and that have a single focal point like a typical direct radiator system. Makes a big difference, these system can image with the best of them.
Rob:)
astrotoy
1,551
1,020
1,715
SF Bay Area
My Avantgarde Duos are about 103db efficient. I wouldn't claim they are the best, but I have had them for over 10 years (bought used for about 10 big ones), longer than any other speaker I have owned, and have always been happy coming back home even after being at Steve's place (when he lived in the Bay Area) hearing his big Wilsons or my consultant's Magico Q7's, Q5's, TAD CR1's etc. Not saying the AV's sound better, but satisfying for me. They are powered by my Cary 2A3 SE amps, 4 watts on an average day. The AV's cheat on power, with the bass unit having a self powered amp and the two horns driven by the external amps.
Larry
PS. My wife is very tolerant of my hifi obsession and not very observant to changes in my system. However, she did notice when the AV's came in to replace my Quad ESL63 US Monitors. She said, "Aren't these new?"
jiannone
22
Danley shouldn't be overlooked. The SH50(PDF) is an extremely competent speaker for its purpose, though beauty isn't its strong suit.
prerich
249
12
923
Volti Audio's products should be considered in this discussion also.
Exlibris
588
429
198
Canada
systems.audiogon.com
I was thinking of starting a thread on this exact topic and then I found this old one. Perhaps we can revive it.
(Note: I was looking at Duke's recommendation but I have to stay away from floor-firing woofers because I live in an apartment building)
