Tonight I am driving the VR5 with a Rogue ST100.
I think the lack of dynamics I hear is the preamp exaggerating them. The more I listen to the X20 direct to the ST100 it sounds amazing, and this is my removing a ARC REF5SE from the chain. Go figure.
Chris,Hi,
i'm new here and find this thread after searching information about the Gustard X20u.
i ordered one 10 days ago and received it last week. This week end i open the lid and I can confirm the USB board is the new one (the one with the 2 modules Accusilicon).
On Head-Fi another guy also opened it last week and saw the same module. What i understood is that all new DACs have this module.
Agreed with my system also. Vrs the Vega and the Yggy, the Gustard wins easily with no mods. AND I really did NOT want it to win, as the Yggy is American born (GO USA!) I wish they had named the Gustard X20 something more exoticFrantz the Vega just leaves too much information out. I prefer a more detailed and pinpoint imaging system and the X20 has delivered.
Now I just have to wait for Lunar New Year to get over so I can order one.Agreed with my system also. Vrs the Vega and the Yggy, the Gustard wins easily with no mods. AND I really did NOT want it to win, as the Yggy is American born (GO USA!) I wish they had named the Gustard X20 something more exotic
Yes that's what I usually find. Give it a couple weeks of listening direct and then go back. This is when you will really realize how much grit the preamp adds. It takes time for ears to adjust.
The preamp is NOT going back into the system Mike. The X20 seems to be made to drive a power amp.
Ric, Tell us what mods you've made and how the X20 is morphing into a real giant killer.
Hmm not liking the "hard as nails" comment. My Gustard is on the truck for delivery today, so I'll find out shortl for myself.
Had to do more mods to the amp and speakers and player but finally yesterday the system was sounding glorious (modded Oppo 103D as source), so hooked the Creamy Custard DAC into the system via homemade coax from Oppo digital out. Very detailed but hard as nails.....yes, I understand the "forced sound" comments now. So, first mod was to bypass the fuse with copper foil......much richer and less hard but still hard.....so next was to change the magnetic steel bolts holding down the transformers to non magnetic brass hardware.....much better and less hard but something missing.....so, I removed the bolts altogether (now there is nothing conductive in the middle of the trannies)......OMG!!!!! Goose bump city.....almost all hardness gone and this thing is now in another whole league (three dimensional holy crap!). All listening done with cover off (who needs a stinkin cover!). How much do these first two mods cost? 2 cents for the copper foil and nothing for the removal of bolts.....How much better does it sound?....well, about $2000 worth......maybe exaggerating a couple of hundred. BTW, this Gustard has had at least 2 weeks burn in before listening (over 300 hours). As the song goes "We've only just begun!". Please try these mods and report back. If bypassing the fuse scares you then get an expensive audiophile fuse. The copper foil I use to bypass the fuse has conductive adhesive on the back (available cheap everywhere). I can mail you enough to cover several fuses for $2 if you like. Warning, warning, warning....Do not bypass fuses in tube products or power amps....warning, warning, warning! You wrap the fuse once only with the copper foil....if it gets too thick you won't be able to re-insert the fuse.
Gustard still has stock feet sitting on maple platform which sits on Oppo which has Mad Scientist Ceramic footers underneath sitting on another maple slab that sits on top of a very non inflated tractor tire. The amp is my own design 25 watt class A two stage all fet dual mono crazy thang and the speakers are hardwired using Neotech 14 gauge Litz.....speakers (92db) are handmade using open baffle B&G Neo 10 and 3 planar drivers on top and two 6.5 inch woofers underneath in sealed box. All xover parts pretty out there and everything hardwired. Felt around the drivers, Ground Enhancers, etc. etc. Shunt volume control in amp. The Gustard at -9 puts out the exact voltage my Oppo does (1.19V). The Gustard puts out 3.3V per phase and then doubles if you use the +6db mode and doubles again in +12db mode. The +12db mode will actually clip the full 0db signal because the output stage cannot swing that much voltage. 3.3 volts per phase is already high.....I have no idea why they did these other two modes.
Next up will be to damp a ringing part and then add WA Quantum dots to DAC chips and capacitors. After that I remove entire output stage and put my own in there. However, I am surprised it sounds so good now with three amp circuits in series with the output (two op amps and then another discrete stage).
Don't panic when you first fire the X20 into your system. Give it a full 24hours powered up and then be critical. If after that you are still in a panic PM me and we will work out me buying it.
if you have a not so detailed system then the edginess is probably not apparent.....but my system is super detailed and revealing.
