Bruce B
Maybe I will get my favourite SACDs re-ripped by you for a fee doing it the right way someday. I don't have that many I listen to a whole lot so may be worth it .......
Be glad to do it!
And how easy is it to do a rip, is it straightforward? How long does an SACD roughly take
Also, do you know if the quality of the rips is better than the PS3 rips, closer to dsd downloads?
I've tested this hundreds of times. There is also missing data in rips since it relies on someone creating the TOC correctly. Just came across a Groove Note with a bad TOC.
I'm not sure where the data is missing? I think it can only occur when the music is continuous over track breaks, and then it's only one sample on each side of the track break, i.e. 1/44,100 of a second total.
Good info. MediaTek indeed continues to list the MT1389 which is an all-in-one optical drive and player hardware. It dates back to 2003 though so very long in the tooth. I can't find any other parts on their site. Did a search for parts and found one Chinese distributor with 1,500 parts in stock.A bit more information on the SACD player chips.
I'm told that SACD players since 2013 use other SACD decoding chips including some made by company nmed MediaTek. This is under the SACD license issued by Sony and Philips. SACD players live on.
I do a direct digital transfer using a Playback Designs MPS-5 and a Sonoma workstation.
This method IS the same as downloads.
I'm told that SACD players since 2013 use other SACD decoding chips including some made by company named MediaTek. This is under the SACD license issued by Sony and Philips. SACD players live on.
Is the transfer done in real time?
Aka - you hit play on the MPS5 and capture the dsd stream in real time on the Sonoma?
Can you capture the dsd stream on a particular track on the sacd disc?
How do you select the track? Via the remote control of the player?
Can the Meitner TSDX with st optical output, also do the same as the MPS5?
Yes, as well as the CDSD and CDSDse
Thanks Bruce.
So now Gus Skinner is the only one selling the Sonoma system?
Are there any alternatives to the Sonoma?
After double checking with Martin Reynolds from dCS, it seems to be the case. Here is what he had written to me:
"There are other CD/SACD solutions, but we have been unable to find one of suitable quality that is available to a small company as an OEM CD/SACD mechanism.
For this reason, after searching for 12 months, we have reluctantly used a CD-only mechanism for the Rossini Player."
Something must be lost in translation during my conversation in Munich with the person I was talking to.
Thanks Bruce.
It looked like a fatal miscommunication to me from the beginning.
BTW, I'm curious if T+A are using an off-the-shelf OEM transport in their new SACD/CD player PDP-3000HV, or is it their own design...
Thay are way to small to design their own.
It's a quite fancy solution though, I don't think I've seen anything like it on any other SACD/CD player...
"The PDP 3000 HV’s high-grade SACD mechanism is fully shielded and housed in a machined solid aluminum case in order to prevent any trace of interaction between the moving parts of the mechanism and the rest of the player. The transport mechanism is mounted on just two close-tolerance pushrods, which completely de-couple it from the massive outer case. This in turn prevents the transmission of external pressure waves, vibration or structural sound from the mounting surface to the electronics and disc mechanism. A high-torque synchronous motor moves the disc carrier block smoothly and quietly by means of a precision-made de-coupled spindle. The loading mechanism makes it easy to insert discs without damaging them; they are held in securely in place by an anti-resonance puck."
http://www.theabsolutesound.com/articles/ta-elektroakustik-releases-pdp-3000-hv-sacdcd-playerdac/
