Dual Connect speaker cables
Wardsweb
413
62
1,585
66
San Antonio, TX
wardswebllc.com
I won't get into the whole cable debate here, but will say with my 2-channel system these made an audible difference in the high end.
MylesBAstor
81
1,725
New York City
Could you tell us a little more about the cables? I haven't run across them in my audio travels :)
Wardsweb
413
62
1,585
66
San Antonio, TX
wardswebllc.com
These are gold plated solid silver core. Two runs per cable covered in a tube of PTFE insulation / two cables per side. They have a resistance of only 0.0033 ohms/meter. Spade terminals are gold plated copper. Not something you want to move around much, but if your system is stable, these work well.
MylesBAstor
81
1,725
New York City
Are you saying they're stiff? I have really come to hate stiff cables because over time, they really put a strain on the RCA connectors, etc.
What do the cables retail for?
Wardsweb
413
62
1,585
66
San Antonio, TX
wardswebllc.com
"Stiff" is a relative term. I guess you really need a reference point. These bend and form easily being a precious metal. Not to be compare with 12awg copper romex or some Maple Audio Whisper solid core cables I had that were difficult at best to bend and use.
Here is a pic taken before I veneered the cabinets, but you can see how the spades worked great with the binding posts on the speakers.
retail for around $1600
MylesBAstor
81
1,725
New York City
Or the FIM/CRL cables!
