I voted it depends and for 2 reasons. Time of day, since I can't really control the lightning in my room. Secondly, I have to be in the right frame of mind.
I voted something in between. Reason is I spin LP's most of the time and I need to see what I'm doing when flipping or changing a record. I just use enough light at the TT to get the job done. If I had a remote controlled light I might turn off the light when seated.
Always off although my Lutron Grafik Eye has 4 scenes programmed with all lights dimmed to different degrees. The 2 GM-70 output tubes give off light equal to 125 watts so ebven if lights are off the tubes compensate. Also I use my Bliss Laser lights depending on the genre of music being played
If (and that happens pretty regularly) I'm into my Prog Rock mode....the lights are OFF. I get enough light coming through the McIntosh logo to make my way to my setup without issue. I also have a light shining on my TT that I can turn on to safely change sides.
i like 'dim'....i have an 'up-firing' can light with a 15 watt bulb behind each speaker.....which works great. i can see to navigate around the room, grab Lps or Cd's easily. and with visitors there is a comfort level that i like. total darkness puts my mind in too active a mode.
here is an old pic of my room with those 'up-firing' lights. it's cheap and easy to do. i leave them on 24/7 and replace those 15 watt bulbs 3 times a year.
I voted for depends. Sometimes I dim the lights, sometimes they're off. No matter how dark the room, my Krell integrated lights the way with its display (and it's dimmed by 50%). Any change in the amp's working parameters lights the thing for 30 seconds.
The light in my room varies depending on the time of day. Obviously during the day it is brighter than at night.
I never measured the luminance before tonight. I don't always have the same lights on in the room. Depending on what lights are on, the night time luminance varies between 0.5 and 2 candelas per square meter. I supposed that could be considered dim to moderate. As a means of comparison, the luminance over my kitchen table is about 250 candelas per square meter which is fairly bright compared to most peoples'.
I'll measure the listening room luminance tomorrow during daylight hours.
One of the benefits of having used the Zone System for B&W [that's Black and White, NOT Bowers and Wilkins
] film photography is having various light meters!
Some of you guys have quite a light display!
EDIT: I just measured the luminance this morning. Outdoor light is in the room but not streaming in the windows due to all the trees around and there are about 10 candelas per square meter--still not too bright. The only time there is light directly streaming in is in the winter when the leaves are down and the time is shortly after sunrise.
