Vinyl collection: do you protect your covers?
MadFloyd
775
1,700
Mass
mep
17
I put a cover on every LP that I care about.
Johnny Vinyl
May 16, 2010
8,570
51
38
Calgary, AB
This! Same with inner sleeves. If I play something that I haven't heard in a while and has no inner/outer sleeve I may add them, but only if I feel it's worth it. Not about to start going through some 3,000 LP's....
jazdoc
3,328
737
1,700
Bellevue
5mm cover and discwasher inner sleeve on every lp
vinylphilemag
Apr 30, 2010
810
1
328
56
Kelowna, BC
www.vinylphilemag.com
I don't have outer covers on most of my records, mostly because I haven't found one with which I am completely happy. My favourites are those used by Impex Records, but they're custom made for that label.
However, I do use anti-static inner sleeves for all my records.
flez007
2,915
36
435
Mexico City
Just about 30% or so have plastic covers, mostly those I care the most, inner sleeves all over as well.
DaveyF
6,129
181
458
La Jolla, Calif USA
I like the sealable Japanese mylar outer sleeves, sold by Music Direct. They have the added advantage of keeping dust away from the top of the cover. Inner sleeves I use are the rice paper Mobile Fidelity. Still going through my LP's and adding these covers, about 90% done.
rockitman
7,097
414
1,210
Northern NY
I use poly sleeves and put the record in them upright so that when I slide the lp in and out of the shelf, the sleeve does slide off. It does require one to remove the poly sleeve the access the record however.
mep
17
That's they way it supposed to be Christian-or at least I think so.
MylesBAstor
81
1,725
New York City
I've always used outer sleeves and for good reason. Once those records get packed in on a shelf, you can damage the covers every time you slide a record in and out.
Currently I use the 5 mil and the box set sleeves from Sleevetown. (they also have nice inner sleeves too as talked about in an inner sleeve article a while back.)
http://www.sleevecityusa.com/LP-Sleeves-Outer-s/1880.htm
MylesBAstor
81
1,725
New York City
I'm not crazy about the Impex-style sleeves since they always end up tearing.
mep
17
OK. Here is one of my pet peeves with record sleeves: How many times have you opened up a brand new expensive record and pulled out the record in its sleeve only to see the sleeve was all bent over in one or more corners? I have a pile of them.
sombunya
133
8
325
I use Japanese resealable as well. A bit of a chore to open and play them but they offer the highest level of protection, I feel.
I've always felt that paper innersleeves were okay, that no real advantage is gained by using any of the various lined inner sleeves. I usually use generic paper to keep some of the printed inner sleeves from splitting or otherwise becoming damaged.
Am I wrong about paper? I have a lot of $$$ tied up here. Should I be using the rice paper sleeves?
DaveyF
6,129
181
458
La Jolla, Calif USA
sombunya, I believe using plain paper inner sleeves is a mistake. Plain paper isn't that soft and has been known to scratch vinyl. The Mobile Fidelity rice paper inner sleeves are IMO the best that you can get, and I would recommend them.
Most collectors keep the original paper inner sleeves on the outside of the cover between the cover and the new outer sleeve. That way, the original inner sleeve stays with the record and doesn't get misplaced.
sombunya
133
8
325
Makes good sense. I'll search for those sleeves asap.
Do you have a good source you'd recommend?
MylesBAstor
81
1,725
New York City
http://www.positive-feedback.com/Issue38/lp_sleaves.htm
Johnny Vinyl
May 16, 2010
8,570
51
38
Calgary, AB
astrotoy
1,551
1,020
1,715
SF Bay Area
I have all of my 15,000 records covered with an outer sleeve. Mostly from Sleeve City. I typically use 3mil plastic. For very expensive records I will often use thicker plastic. For my many box set I also use a larger sleeve, I think 14" square, which fits all but the very biggest boxes. I replace all of the inner sleeves except for audiophile pressings which already have rice paper or other similar sleeves.
Larry
